  • lupusbytes
  • lupusbytes's Avatar
driver: atlantic
version: 6.14.7-gentoo
firmware-version: 1.3.24
After the update it showed
driver: atlantic
firmware-version: 1.3.33
After rebooting I had no network.
  • The lights are on in the network interface
  • The operating system recognizes the NIC and thinks it's active; enp13s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
  • The switch recognizes a link
  • No packets can be sent or received. tcpdump only shows "unanswered" ARP traffic from the interface
  • lupusbytes
I fixed my issue.
It was as simple as pulling the power cable after updating. See also www.station-drivers.com/index.php/en/for...r-edit?start=80#4865
  • jumpy76
  • jumpy76's Avatar
1 year 1 month ago
I'm trying to update the AQC113CS on my MSI Z790 Godlike Max, I get this error:  A driver can't load on this device Do you have a suggestion? Disable Windows drivers signature perhaps?
Thank you very much!
  • jumpy76
  • jumpy76's Avatar
1 year 2 weeks ago
Can someone help, please? I disabled secure boot and core isolation (it's 0 in regedit), but I still get the message "impossible to load atlAccess.sys driver".
1 year 2 weeks ago
