- nightfly2000
3 months 6 days ago
Any new solutions?
I have also a Asus B550-F and bricked my device after updating it to 1.94.
I wasn´t able to downgrade to 1.89 again, because I got an FLASHimage authentication failed.
Saidly I have no Backup...
3 months 6 days ago
could you send us a picture Thx
The following user(s) said Thank You: nightfly2000
- nightfly2000
3 months 6 days ago
I managed to flash the nic in ubuntu. Now it worked also in windows. But I think I have mixed firmware 1.89 and 1.94.
The eeupdate doesn´t work in Windows and give me still the error.
Now it´s possible to use nvmupdate again.
I write down my old Device ID etc.
VENDOR: 8086
DEVICE: 15F3
SUBVENDOR: 1043
SUBDEVICE: 87D2
Now I have this:
VENDOR: 8086
DEVICE: 15F3
SUBVENDOR: 1043
SUBDEVICE: 87D2
Now I have this:
Config file will not be read.
Inventory
[00:007:00:00]: Intel(R) Ethernet Controller (3) I225-V
Flash inventory started.
Shadow RAM inventory started.
Flash inventory finished.
Vendor : 8086
Device : 15F3
Subvendor : 17AA
Subdevice : 22D8
Revision : 3
LAN MAC : xxxx
Alt MAC : 000000000000
SAN MAC : 000000000000
ETrackId : 800002FC
SerialNumber : 7C10C9FFFF3D9EA0
NVM Version : 1.137(1.89)
PBA : N/A
VPD status : Not set
VPD size : 0
checksum : Valid
3 months 5 days ago
If you are on Windows 11, go via Windows PE
3 months 2 days ago
@nightfly2000I have the Intel i225 controller on my X870E mobo and it's a terrible device anyway,I installed the driver for my device the first time I used my new system then I had to do a reformat and install Windows again and the driver installed fine but then my PC would disconnect from the Internet all the time,after I did a bunch of research I found out that the i225 has a lot of problems with not staying connected to the Internet.
I know your not having problems with your i225 disconnecting from the Internet but I purchased this PCI-e card as it is a cheap solution with a Realtek RTL8125B and if you get that card the driver hosted here at station drivers for it as well.
If you only have spare long PCI-e slots and no short ones this card will still work just fine in a long or shirt slot as well,I have tried it both ways.
www.aliexpress.com/item/1005005967045605...in.68.19521802aiNHEG
