S.M.A.R.T display not reading properly after updating (Fanxiang MD-86)
Realtek RTL9210(B) NVMe/USB 3.1 Controller firmware Version 1.34.29.011325
1 month 3 weeks ago - 1 month 3 weeks ago
Realtek RTL9210(
Release note: Fixes an issue with random SSD disconnection
RTL-9210 Nvme/USB 3.1 Firmwares
Gigabyte Z890 Master, Intel Cpu Core Ultra 7 265K, Memoires 32Go Corsair DDR5 (6000Mhz CL30), Water-cooling Thermaright, nVidia Geforce RTX4060, Alimentation Gigabyte 850W, Samsung SSD 990 Pro, SSD9100 Pro, Clavier Razer Black Window , Souris Razer, Boitier NZXT H6, HP Steelserie, Free Fibre Ultra (8Go/8Go), Lan 10Gb, Cable CAT8/7, Switch 10/5/2.5Gbps, Casque Philips Fedelis.
Last edit: 1 month 3 weeks ago by admin.
Re: Realtek RTL9210(B) NVMe/USB 3.1 Controller firmware Version 1.34.29.011325
link isnt working it just goes around in circles
Last edit: 1 month 3 weeks ago by Shonk.
1 month 3 weeks ago - 1 month 3 weeks agoConfiguration
- rococoricoco
1 month 2 weeks ago - 1 month 2 weeks ago
Hello everyone. I have a problem.
I have Fanxiang MD-86 with RTL9210B. I just updated firmware to 1.34.29.011325, somehow the display can't read S.M.A.R.T from my SSD (XPG Gammix S70 Blade 1TB) after updating. Perhaps someone here can help me to find out the problem.
I'm using UTHSB_MPtool_Lite.exe to update it, and i checked Firmware Update and PG, do i did something wrong with that? I attached photos for some info.
Thanks before.
Thanks before.
Last edit: 1 month 2 weeks ago by rococoricoco.
Re: S.M.A.R.T display not reading properly after updating (Fanxiang MD-86)
Hi, you have to be careful because the RTL9210 firmware has several versions depending on whether the case has a display, RGB backlighting, etc.
The firmware is different.
Last edit: 1 month 2 weeks ago by admin.
