Updating firmware to Asmedia 1142 brick my 2 x USB 3.1 ports
Re: Updating firmware to Asmedia 1142 brick my 2 x USB 3.1 ports
you try to deactivate the usb port of the setup then reactivate it
Try to see if the utility of the latest firmware works
ASM-1142 USB 3.1 Controller (station-drivers.com)
  • Bolo
  • Bolo's Avatar Topic Author
I try  to deactivate the usb 3.1 ports of the setup BIOS then reactivate it. Same issue. Asmediatool does not detect firmware, so can not start update firmware. See the attacked screen shot.
so the firmware crashed and did not finish the procedure due to what?
Try to see on Winraid if anyone can help you because I have no other solutions
  • Bolo
Before kill me usb 3.1 app show firmware. After that does not show.
By the way USB 3.1 from sabertooth x99  has maximum speed of 638 MB/s. I try to update the asmedia beleve  in new firmware that will increase speed, but kill my usb 3.1 .
Now I purchase a pciex asmedia card usb type C with support up to 20Gbps.
