- kurac338
I appreciate your help, and I've found that release myself on the Asus forums. I will give it a try, but honestly I dont expect anything to improve
In the meantime since my last post I have broadened my troubleshooting search out of desperation and have fallen into the disaster wonderland pit that is Intel's "Foxville" 2.5Gbps NIC lineup (I225, E3100G, ...). The more I research, the more pessimistic I get
There was an official Intel acknowledgment for the I225 NIC that it had a hardware design fault. Here is the "errata" for that:
[url] www.intel.com/content/www/us/en/support/...rs-up-to-2-5gbe.html [/url]
(Technical description is below the table in the "For official communication on this issue" link)
Supposedly it was fixed properly in I225V2 and I226 NIC hardware.
However, there are mentions of NIC firmware updates, NVM updates, and corresponding drivers for existing users unable to replace their hardware.
So my issue is layered, and I will try to outline it below:
- E3100G is not explicitly mentioned on the Intel I225 errata post, so I don't know if the FW, NVM and driver updates are applicable for me (even though it is considered in the same product "family")
- my understanding is that E3100G is a direct rebrand of RTL8215B(G), as the older Realtek drivers had explicit "support" for Killer E3100G, and the Killer driver .inf has explicit references for E3100G=RTL8125B(G), further increasing my doubt that I225 "fixes" could work for me
- newer Realtek NIC drivers have stopped offering explicit E3100G support in their .inf as outlined by Tom in the posts above, so a forced manual install is the only option with no guarantees that it will work at all
I have also emailed ASRock's customer support to try and get any official recommendations, software fixes, etc., or possibly a board replacement. Again, I am not optimistic that any of it will result in a positive outcome, especially since ASRock did not make a newer ITX board after the B650E chipset to replace/remedy this fault.
P.S. I did not mean to "hijack" this thread with Intel related issues, however this is a pretty distinct/overlapping situation. I appreciate any hints, tips and help from this community
Last edit: 1 year 6 months ago by kurac338.
1 year 6 months ago
It is true the Intel i225 has a fault,I have an ASUS X870E ProArt mobo and I really like it but the intel i225 will sometimes never turn itself off and then sometimes it will.
With my problem I can reinstall Windows and it's like playing the lottery one time it will work perfectly fine and never give any problems and the next time it give problems that can not be fixed and then you have to keep trying to reinstall Winodws until it you get a good driver installation.
1 year 6 months ago
1 year 5 months ago
Windows 10/11 v10074: (10.074.1128.2024 - Gigabyte OEM)
{ Gigabyte download site 1 } { Gigabyte download site 2 }
- pug101
1 year 5 months ago
Theres a 3/28 update on the realtek site but seems like they're the same versions as before? Either way just letting you know
