  • Tom's Avatar
Re: Realtek PCIe FE / GBE / 2.5G / Gaming Ethernet Family Controller Software for Windows 7-11
3 years 5 months ago
You probably will face the same problem. Even the binary is increased in filesize by adding support for additional models, but the driver still stays the same version 1125.011.1206.2022 (dated December 6, 2022).
  • virgolicidaniel
  • virgolicidaniel's Avatar
I can't figure out what went wrong with that driver. Been running newest since you posted and it didn't act weird, not even a second. Previous driver install was clean, removed all related drivers and the app (uninstall from installer, also checked with rapr), stock properties, re-installed, changed some properties, cmd ip commands, router reset and whatever came to my mind.
My Setup
Which chipset are you having the problem with?, I have an RTL8125 but I have no problems
  • Tom's Avatar
He is using the Z490. I use the B550 chipset and face also no problems.
Last edit: 3 years 5 months ago by Tom.
There were issues with some Realtek RTL8111 chipsets with the release of Windows 11 but I thought this was resolved
