AMD Ryzen Master Overclocking Utility
2 years 11 months ago - 1 week 6 days ago
AMD released v2.10.3.2419 on April 25, 2023
Release Highlights:
Release Notes: www.amd.com/en/support/kb/release-notes/...n-master-2-10-3-2419
Release Highlights:
- Memory overclocking support for AMD A620 chipset based motherboards.
- Issue related to CPU Voltage range is fixed. Users can now apply voltages beyond 1.52V.
- Not all features are visible or supported on Legacy Processors.
Last edit: 1 week 6 days ago by admin.
Re: AMD Ryzen Master Overclocking Utility v2.10.x.xxxx
AMD released v2.10.3.25042514 on June 515, 2023
Release Highlights:
Release Notes: www.amd.com/en/support/kb/release-notes/...n-master-2-10-3-2504
Release Highlights:
- On systems with AMD Ryzen™ 7000 series processors, the Ryzen Master menu setting for SoC voltage input is limited to 1.3V when not in LN2 mode.
- Issue related to CPU Voltage range is fixed. Users can now apply voltages beyond 1.52V..
Last edit: 2 years 9 months ago by Tom. Reason: Update to v2.10.3.2514. Links stay the same
2 years 8 months ago
AMD released v2.11.1.2623 on July 26, 2023
Release Highlights:
Release Notes: www.amd.com/en/support/kb/release-notes/...n-master-2-11-1-2623
Release Highlights:
- Security updates included in this release.
- None
2 years 7 months ago
AMD released v2.11.1.2659 on August 9, 2023
Release Highlights:
Release Notes: www.amd.com/en/support/kb/release-notes/...n-master-2-11-2-2659
Release Highlights:
- None
- porkdelicious
2 years 4 months agoAMD’s Ryzen Master gives users advanced, real-time controls over their system’s performance.
scratch geometry dash
Release Highlights:Fixed Issues:
Known Issues:
Users can customize everything from individual cores to memory voltages and pretty much everything in between using the software.
