Intel Network driver I219V
- tistou77
Bonjour
C'est mieux d'utiliser les derniers drivers officiels : Intel Network Connections Software Version 30.0
Ou utiliser ceux là ne pose pas de problème : Station-Drivers - I217,I218,I219 V_Intel_v12.19.2.61 Standalone Driver Release 05.05.2024 - Forum
Merci
Merci
Last edit: 2 months 2 weeks ago by admin.
- Newf
- tistou77
Re: Intel Network driver I219V
Ok merci
2 months 2 weeks agoConfiguration
- tistou77
2 months 2 weeks ago - 2 months 2 weeks agoLL A77F - Rampage VI Extreme Encore - 10980XE @4.7ghz - G.Skill Trident-Z RGB Royal 4x8Go @4000 C16 - EVGA RTX 2080ti XC Ultra - Seasonic Prime Ultra Titanium 1000W - Intel Optane 905P et Samsung 990 Pro - Asus Xonar Phoebus
Last edit: 2 months 2 weeks ago by tistou77.
