4 months 2 weeks ago
#3916
Yes normal but does the new firmware work because from version 17.xx to 22 weird
#3917
If it works well, leave the latest firmware normally I advise to update it on a USB 2.x port because the USB 3.x sometimes crashes the update
  • teomialo
  • teomialo's Avatar
  • User
  • User
#3918
On a USB 2.0 port, my hard disk makes clicking noises ?
The upgrade was successful with USB 3.0 despite the FAIL message, but the slowness is still there the first time I plug it in when I copy a file.
I've just reinstalled the original firmware, which is a shame.
#3919
  • teomialo
  • teomialo's Avatar
  • User
  • User
#3920
The link is broken... 200416_D1_48_02
"Fatal error - attempt to access unpublished file by non-admin user"
what are the changes compared to 220906_D1_45_01 which I have just tested ?
otherwise I found this. With a more recent version of MPTools, however, everything is grayed out ?
I can't select the firmware.
station-drivers.com/index.php/en/forum/e...sion-200416-d1-48-02
[img
